Ducted mini split – 18k or 24k?
![](https://secure.gravatar.com/avatar/c15cf71d5d14c302b85e40d4ca86e3f5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Looking for some input on selected a mid-static ducted mini split for a 1500 sq ft 1960s brick ranch in Durham NC. This will be my third ducted mini split install (previous were a Fuji 7k+12k and a Fuji 18k at previous houses). Manual J is attached (left out some closets and a stairwell which is why the sq ft is slightly off). Ducting will be going in an encapsulated attic space. Considering either:
Fujitsu 18RGLXD – 18k, 19 seer; 0.8 wc; $3100 ish
Midea DLCSRBH24AAK – 24k, 21 seer, 0.64 wc; $2300 ish
I’ve had good luck with my previous Fuji installs and would be happy to do another, but concerned the 18k is a little undersized (acknowledging 18k rated = 21.5k max). Unfortunately the 24RGLXD is discontinued (I presume the 18 isn’t far behind) and next step up is a 30.
Midea is a good bit cheaper and from what I’ve read seems like it would be just fine if well installed.
I’ve mapped out a relatively straightforward duct arrangement (further simplified in the attached diagram) and feel confident I can fabricate nice smooth transitions to make it work with either unit. Really only concerned with cooling capacity… living room has a gas fireplace we use in the winter which does a good job keeping the living area warm. Would the 18k Fuji cut it?
