Ducted and ductless heads on a zoned mini-split
![](https://secure.gravatar.com/avatar/67eb89961f6ca52ad49e9e5a0417baf1?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I performed an energy audit for a homeowner who is interested in a zoned mini-split system.
My question is whether a ducted indoor unit can be used in, say, a master bedroom suite, while a ductless indoor unit can be used in a different zone but with the same outdoor unit; or do all zones have to use the same type of indoor unit — all wall mounts, all floor mounts, all ceiling insert, etc.?
My second question is whether different zones can use different-btu/h indoor units (e.g., small family room gets a smaller indoor unit than a large living room, etc.).
As always, thanks in advance for your insight.
Most multi-zone compressors will accomodate mini-duct cassettes as well as wall-coil heads, with a mix of sizes.
As an example, the 2-zone Mitsubishi here lists the compatible heads/cassette that will work with the compressor unit, which includes both ducted & ductless units of varying sizes, as well a ceiling cassettes, etc.:
http://usa.mylinkdrive.com/categories/3/product_types/5/series/42/models/65/products/show/681.html
Fujitsu & Daikin have similar 2-zone systems with similar head/cassette compatibility listings.
