Duct or not to duct?
![](https://secure.gravatar.com/avatar/24e8f05ed1da58d86b2c82f33dace667?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I know conventional wisdom dictates that ductwork should come off the trunk line and radiate out towards the exterior walls so registers can be placed above windows. I should say that I’m talking about New Orleans where homes are raised about 18″ off the ground on piers, so we run the ductwork through the attic. If it’s a two story house there is no room for chases between the floors. My question is, if one has a load bearing wall running the length of the structure,with living areas on either side, could you not run a soffitized duct on either side of the wall with vents in each room dispersing heat & A/C from the middle of the house, eliminating runnnig duct work out towards the windows? What would be the pros & cons of this? Thanks for your insights.
Roger,
Designers of tight, energy-efficient homes often locate forced-air registers or diffusers near the center of the house rather than at the perimeter. This approach works well if the house has a very low rate of air leakage, has above-average levels of insulation, and has high-quality windows.
If the house is built conventionally -- with average rates of air leakage, ordinary fiberglass batt insulation, and inexpensive double-glazed windows -- occupants can be uncomfortable unless the registers or diffusers are located near the building's perimeter.
Thank you again Martin, You are a veritable fountain of information & inspiration.
