DualCore HRV – TEMPEFF RGSP-K – Anyone used, installed, or spec’d this new Canadian HRV?
![](https://secure.gravatar.com/avatar/d00b0a4d8ff4752c15a890d49f2c71b6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fo.png&r=g)
Hello, a fellow GBA contributor made me aware of the new’ish Canadian HRV from TEMPEFF. Has anyone used, installed, spec’d one of these? Has GBA done a review to your knowledge?
It is advertised as follows:
– “is up to 92% sensible and 70% latent heat recovery in winter without the need for a defrost strategy”;
– has the “ability to fit even the most compact layouts”;
– “up to five different configurations”;
– never frosts even to -40C (or -40F);
– different models capable of 100 CFM to models with 1,600CFM
Sell sheet
https://www.tempeff.com/wp-content/uploads/2022/09/14094-Tempeff_RGSP-K_Sellsheet.pdf
DualCore calculator online
https://www.tempeff.com/dual-core-difference/#pc
This article mentions a cost of $5,000 and up.
https://www.tempeff.com/insights/researcher-says-theres-a-better-way-to-ventilate-homes-in-the-north/
DUALCORE PERFORMANCE CALCULATOR
To add, this is the link to NRC's report on that unit:
https://www.canada.ca/content/dam/polar-polaire/documents/pdf/publications/aqhaliat/2019/energy-recovery-ventilation-system.pdf
Hugh, also a type in your thread title..."Tempeff" is the correct company name :-)
Also attached is the pdf spec sheet for the smaller (configurable package) RFSP-K 100ECM . The cores are aluminium and built in-house. That smaller unit (100 CFM) has two cores which are more or less 46" long and 11" x 9" OD.
No preheat or defrost strategy is required, nor is there any interruption in exchange air. For colder climates not needing pre-heat or ground loop, this not only drops the install cost, but also reduces ongoing operating costs.
