Dual zone ductless
One outside unit &two inside units, summer no issue ,winter impossible
to control the temperature in my bedroom problem heat transferring from lower unit to bedroom unit if lower unit is set to 75F ,upstairs set to 65f the room gets to hot for sleeping even in fan mode heat is still blowing out, solution close the upstairs unit in the winter bedroom door always closed.Sharp tels me that this normal with all the makes dual zone systems. Any help would be appreciated
Regards
TIClaude,
Stack effect may be contributing to your comfort issues. Can you tell us where you live a bit about your home?
