Dual fuel heating system – thermostat?
![](https://secure.gravatar.com/avatar/a1a5e6f941533bc5634c4f0709f91880?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
We recently built an addition onto our house and instead of extending our existing AC-only system, we installed a second AC/heat pump system. The house also has an oil-fired boiler with baseboards.
We added two heating zones to the addition onto the existing hydronic heating system, so the addition has two heat sources – oil and heat pump.
My question is this – is there a thermostat available that would only fire the boiler when it gets cold enough for the efficiency of the heat pump to drop below a certain rating? Here in western VA it often gets warm enough – like today it is 47F outside – that I believe the efficiency of the heat pump should exceed that of the boiler.
What I would like to have is a thermostat with an outdoor temperature sensor that allows me to use the heat pump when the temps are moderate, and the boiler when it drops below a certain temperature.
Thanks for any help you can provide!
Vision Pros and most Prestige by Honeywell can be set up to do what you desire. You may want a pro to do so for you.
http://yourhome.honeywell.com/home/Products/Thermostats/7-Day-Programmable/SummaryList.htm
The heat pump is programed to be locked out at your desired temperature via the tstat.
Awesome, thanks AJ! I've been wanting to try out a thermostat that I can connect to my home's network anyway, so it looks like I might be able to find one that will control both systems and be accessible over the network. I'm a software engineer/IT guy so I'm a geek when it comes to hooking things like this up :)
I'll report back my results once I get it all hooked up.
Thanks again,
Eric
