Drywall on 24 inch o.c. framing?
![](https://secure.gravatar.com/avatar/6fe7085ce52ab95ae9c678e691a4e0cb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
user-1137156
| Posted in Energy Efficiency and Durability on
Are there any issues with using 1/2″ drywall on 24″ o.c. framed walls?
Jerry,
Q. "Are there any issues with using 1/2-inch drywall on 24 inch o.c. framed walls?"
A. No. This installation meets code as well as manufacturers' recommendations. (See, for example, this document from U.S. Gypsum.)
If you are installing 1/2-inch drywall on ceilings that are framed 24 inches o.c., make sure that you specify sag-resistant drywall and that you install the drywall perpendicular to the framing.
THANK YOU Martin! That's the answer I hoped for.
Cheap versus luxury....
Same with drywall verse plaster walls.
5/8" feels like a solid wall just like solid doors cost more but feel like luxury verses $30 lusn hollow core or worse the doors made of pressed paper.
