Drywall instead of osb as vapour retarder/air barrier on ceiling with service cavity
![](https://secure.gravatar.com/avatar/43606de476a0f4faeed0c3074c2931f2?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I see a lot of osb used to make a vapour control layer and air barrier on the ceiling then furring down 1.5″ for a service cavity. Can a person use drywall and tape to achieve the similar results? I don’t know if the seam tape is rated for drywall but it should achieve the same result.
You may need to add vapor retarder paint to get the perms you need. Or a smart membrane.
thank you. Would be a safe way to add a little insurance to the assembly.
