Drainage mat behind stone veneer?
![](https://secure.gravatar.com/avatar/7e9ea2ef0214d1f7c99d975e6f0b9019?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Question:
Is it preferred to have a drainage mat in the air space with a stone veneer (as I typically specify – EnkaDrain-standard) )
OR
Is it OK/ better to delete the mat and the air space (to minimize the opportunity to form condensation) and fill behind the veneer solid with mortar?
I would provide weeps at the bottom of the wall for water to escape in any case.
Thoughts?
Debra,
You want the drainage mat and the air space -- for sure. Adhered stone veneer installations are VERY problematic, especially over OSB.
More information:
Stone and Synthetic Stone
Weep Screeds Behind Manufactured Stone Veneer
To Install Stucco Right, Include an Air Gap
