Dow Corning Contractors’ weatherproofing sealant – uses and evaluation
![](https://secure.gravatar.com/avatar/1da902b62eef888f571e7a85405c8162?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Hi, what are the uses of Dow Corning Contractors Weatherproof Sealant? Is it good as a liquid flash or an air seal on wood, OSB, concrete?
It is silicone based I think, and silicone does not get my attention as a sealant I will use in building my house/shop.
Edit:
I found out that it is good for smooth surfaces such as glass, aluminum, concrete, granite, etc… Has 5 year warranty. Here is where I saw a little more info: Turns out the name was changed to Dowsil CWS
https://coastalone.com/dowsil-cws-20oz.html
Thank you.
-Mike
