Double stud exterior wall insulation
![](https://secure.gravatar.com/avatar/85303c7fd83ace9bad549e257c32f74f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
Hi,
I’m renovating a home in climate zone 6B. We are recycling as much building material as possible. The exterior walls are 2×4 with 2″ mineral wool batts. I have a lot of 3″ fiberglass batts from the ceilings that we removed. Is it okay to compress the 3″ fiberglass and 2″ mineral wool into the 2×4 stud bay? I know compression is okay but I don’t know if the double kraft paper has an adverse effect.
The plan is to attach faced eps or iso (1-2″) with seams taped as the inner wall air barrier. Then frame a 2×3 or 2×4 wall with batt insulation as the interior wall.
Thanks,
If the black facer on the mineral wool is in fact asphalt-saturated kraft (?) you should be fine. Kraft won't trap moisture.
