Door flashing detail
![](https://secure.gravatar.com/avatar/145dd045730f19ff03d3c6ceab0fe693?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
We are in Minnesota (Zone 6a). 2200 sq/ft single level (9′ walls), slab on grade.
Is a recess in the slab the preferred method for pan flashing a slab? I have several innie doors, 1 outie doors and 1 sliding patio door. How deep should these be? 1/2″?
This is the picture I meant to attach.
This is discussed in another thread: https://www.greenbuildingadvisor.com/community/forum/green-building-techniques/40788/exterior-door-details-4-thick-foam-walls
Thanks Steve. Yes I saw that. It's where I got the picture from. It's not really discussed what the preferred mwthod is when starting from scratch. That poster was trying to fix a problem on an existing home.
Scott,
Every exterior door needs sill pan flashing. For a slab-on-grade home, creating a "seat" in the concrete as shown in the Building Science Corporation document make sense. It's probably the best -- but not the only -- way to provide sill flashing in such cases.
If you prefer, you can use a conventional technique (peel-and-stick flashing or metal flashing), as long as the flashing technique you have chosen doesn't interfere with your flooring installation.
Here is a link to the Building Science Corporation document where the illustration came from: Pan Flashing for Exterior Wall Openings.
