Does having a thicker wall thickness mean that OSB sheathing can not be used?
![](https://secure.gravatar.com/avatar/d4366edf3752231edb0b917b552aeb9c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
With a thicker wall thickness, the exterior side of the wall will be cold, and stay cold longer. Look at any thermal analysis. Using OSB as your exterior sheathing might be a good idea since it is more susceptible to moisture, correct?
Nathan,
I think you mean "bad idea," not "good idea." To read more on this topic, see How Risky Is Cold OSB Wall Sheathing?
