Does Great Stuff shrink?
![](https://secure.gravatar.com/avatar/730c9ca1edd7d9bb00821a0565e43196?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
user-231615
| Posted in Energy Efficiency and Durability on
For 1/2″ gaps, should I use Great Stuff or the 2 component foam? Which bonds better, shrinks less?
John,
Neither product should shrink if properly installed. Both products are tenacious. However, neither product forms a perfect air seal, and it can sometimes be hard to fill a narrow crack that is only 1/2 inch wide.
Other options (especially if your chief concern is air sealing) include caulk and a high-quality tape, especially one of the European tapes designed for air sealing.
If you have consistent 1/2" gaps, it's easy to use foam backer rod instead of canned foam.
