Does EPS shrink with time?
![](https://secure.gravatar.com/avatar/894ce96c8ffd7ff65e8c0d8f1f4f0e5c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
On the following link a comment was made that I have concerns :
https://www.greenbuildingadvisor.com/community/forum/green-building-techniques/34270/i-am-thinking-using-huber-s-new-zip-system-r-sheathi
“On the foam, two layers is better than one, with seams taped on both layers, and overlapped by a foot. Over then next 40 years the EPS is going to shrink a bit, but the performance hit won’t be too bad if the seams are overlapped and still reasonably air-tight.”
Answered by Dana Dorsett
I was thinking of using a product called InSoFast because of the Embedded Polypropylene Attachment Studs, but after reading the comment above, Will this cause more problems than it’s worth later in the future?
