Does an underground CMU stem wall need to be dampproofed?
timgodshall | Posted in Energy Efficiency and Durability on
I am building a house in Harrisonburg, Virginia, with a suspended front porch concrete slab. One side of the slab rests on a 4″ ledge cast into the poured concrete house stem wall. The other side rests on an 8″ CMU wall that extends down about 10 feet to undisturbed soil. I am planning on back-filling soil most of the way on both sides of the CMU wall.
Do I need to do any damp- or water-proofing of the CMU wall for structural reasons? I read another thread on GBA talking about how water and salt will gradually eat away concrete. Will a subterranean CMU wall gradually disintegrate if not properly sealed? If so, what is the best way to handle this situation?
Here’s the blog post I read on efflorescence:
https://www.greenbuildingadvisor.com/blogs/dept/building-science/efflorescence-water-damage-building-science-podcast
  1. GBA Editor
    Martin Holladay | | #1
    Timothy,
    I don't think there are any structural reasons for dampproofing. Nor is there any reason to worry about efflorescence. Typically, the above-grade portion of this foundation would be coated with stucco (cement-based plaster), at least on the exterior side, for aesthetic reasons.
  2. timgodshall | | #2
    Thanks for the reassurance, Martin. We're planning to put brick on the outside for the aesthetic part.
