Do I require a fresh air intake for my fan coil (forced air system)?
![](https://secure.gravatar.com/avatar/957988d2a96b39884f1a314863b703a4?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I have a Bosch in slab heating system in the basement and the upstairs is heated with a fancoil. Heat is derived from my domestic hot water system which is also heated by the Bosch Boiler. Why would I need, or do I, nedd fresh air to the fan coil?
Ron,
The main reason you might want to introduce a little fresh air to your house would be if your home's thermal envelope (floors, walls, and ceiling) are relatively airtight.
For more information on mechanical ventilation systems, see Designing a Good Ventilation System.
