Do I need to install an underlayment?
![](https://secure.gravatar.com/avatar/6b7832784701f20321d404a337c6b278?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
EHt2PWoEKw
| Posted in GBA Pro Help on
Do I still need an underlayment on a first-floor hardwood floor if I have a conditioned crawlspace with a vapor barrier on grade?
To what kind of "underlayment" do you refer? Vapor retarder? Particle board? ???
No you can nail hardwood directly over a layer of red rosen paper to 3/4 plywood or osb subflooring on the floor joists. This is assuming that you are using conventional sanded in place solid wood flooring. a floating, engineered wood flooring may be a different matter.
