Dimple board on a pre-cast concrete basement
![](https://secure.gravatar.com/avatar/23e4f257ac4471697aa560cc2b248528?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I just had a pre-cast basement installed that uses 8000 psi concrete. The majority of the basement is below grade. They told me that I don’t have to do any type of water proofing, but since I haven’t back-filled yet, I’m going to go ahead and do it anyways for peace of mind. I like the idea of the dimple board membrane except for the fact that you have to nail it into the wall. I don’t want to create holes in a wall that is solid! Any ideas if I can install the dimple board without nails?
Thanks in advance!
Be sure to read the terms of your precast warranty. Make sure adding exterior waterproofing won't void your warranty.
Not sure about driving nails into the wall (which I don't want to do anyways), but applying a water proofing membrane won't void the warranty
Andy, besides sheet products, I'd recommend considering:
http://www.decoproducts.com/deco-20-seal/
I used it on my forever home which is certified LEED Gold.
Andy,
I don't think that nails will hurt your concrete foundation. But why not call up the manufacturer and ask about their recommendations and warranty terms?
@Andy. I can understand your anxiety about the basement system. (I installed two footer drains since there was no consensus about optimal placement.) Maybe this inspection page would be helpful: http://inspectapedia.com/structure/Pre_Cast_Concrete_Foundations.php. It at least provides some guidance on things to observe that might suggest installation problems.
