Design of a ground loop system for an ERV
![](https://secure.gravatar.com/avatar/545660f0815700e0badbb9bdc679ae50?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I am building a new house near Albany, NY which is region 5A. I plan to have a super-insulated house with an Ultimate Air ERV. I would like to hook up a ground loop system to the ERV which would consist of tubing that is looped around the foundation footing a couple of times which would contain water or an anti-freeze mixture. The liquid would be pumped through a water to air heat exchanger on the intake side of the ERV in order to raise the input air temperature during the heating season. Where can I find design details for a system like this? What kind of tubing should be used? Is an anti-freeze mixture needed?
Robert,
There is an illustration of such a system in a document posted on the Ultimate Air web site:
http://www.ultimateair.com/Portals/92089/docs/UltimateAir%20&%20Passive%20House%20web.pdf
I suggest that you contact the company for help with your technical questions.
UltimateAir
178 Mill Street
Athens, OH 45701
800-535-3448
740-594-2277
Fax: 740-592-1499
The best person to talk to at Ultimate Air is probably Jason Morosko.
