Densglass & Stucco
![](https://secure.gravatar.com/avatar/5730210db14ba879cf3601ecc4361563?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
Can one apply EIFS or stucco directly to DenGlass or does one need to treat DensGlass like wood/OSB sheathing?
Can DensGlass be used on a soffit with it directly being applied to the OSB sheathing?
Peter,
According to the manufacturer of DensGlass Gold, Georgia-Pacific, "Most exterior sidings and wall coverings — including wood, vinyl, composition, metal, stone, brick, stucco, wood shingles, shakes and plywood panels — may be applied directly over Dens-Glass Gold sheathing with excellent results."
Here is a link to a pdf document from Georgia-Pacific with more information:
http://www.buildgp.com/DocumentViewer.aspx?repository=BP&elementid=4922
See the image below for more details.
Peter,
One more point: while you can probably trust the Georgia-Pacific detail for water-management issues, you certainly can't trust it for energy details. The depicted detail -- steel studs without any continuous insulation, but only fluffy stuff between the studs -- is an energy disaster.
