Dense pack cellulose roller: Where to get one?
![](https://secure.gravatar.com/avatar/7d42675a8652e0bbb61cc7e60128b078?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
As a fan of the dense packing method of cellulose in Atlantic Canada, I often run into a few key challenges from contractors:
1 – It’s dusty (…not really when dense-packed)
2 – It’s different and learning is required.
3 – Not wanting to use strapping (due to added cost) to manage the bulge at 3.5 lb densities.
The common response is to use a hard roller long enough to push the cellulose in. The problem is no one (myself included) knows where to get one? Can you please make some recommendations?
Thank you!
MB
Matt,
For years, the answer to your question was simple: You can buy a cellulose roller from National Fiber in Belchertown, Mass.
Unfortuately, National Fiber is out of business. The company was purchased by a rival, GreenFiber. It appears that the reason that GreenFiber purchased National Fiber was so they could shut it down. I just got off the phone with a GreenFiber representative, who told me that GreenFiber does not sell cellulose rollers.
I just called Bill Hulstrunk, the cellulose expert who used to work at National Fiber. I got his voice mail. I left a message; when I hear back from Bill, I'll share what I learn.
Below is a screen shot of the relevant page from the old National Fiber catalog.
You might check out this vendor: http://www.idi-insulation.com/product/parts-coveralls-tools/
It seems likely they would have what you want.
Thank you Martin - I've been looking at alternatives this morning (floor rollers etc.) but there doesn't seem to be anything quite up to par. I'll stay tuned.
That roller looks a whole lot like the roller stand at Harbor Freight:
https://www.harborfreight.com/132-lb-capacity-roller-stand-68898.html
The roller is 11" wide.
Mark, I think you are right that that would work well. Both items were on my jobsite at the same time, and they are indeed quite similar. I didn't try using the roller stand for insulation, but I see no reason it wouldn't work.
Does the roller come out of the stand? I presume yes, but just checking. Also, where there is no need for a stand ideally this would be sourced elsewhere. I'm looking into conveyer belt companies now...
Matt, the silver support comes out of the black legs. At $17, a double-duty tool is a great value.
True, That's decent value for $17. Great for the US, just checked and no luck on shipping to Canada...
Matt,
check crappy tire:
http://www.canadiantire.ca/en/pdp/trifunction-stand-0556841p.html#srp
Or princess:
https://www.princessauto.com/en/detail/folding-roller-stand/A-p8044653e
or home depot:
https://www.homedepot.ca/en/home/p.tool-master-roller-stand.1000138530.html
all decent alternative, where the stand and support should separate. all 12" wide. and double the price of something similar stateside :(, but apparently the US is on the bad side of nafta?
Matt,
I just heard back from Bill Hulstrunk; his response was delayed because he was out of town.
Bill said, "I have ordered wall rollers in the past from Insulation Machine Corp. (800) 438-2776 and Energia (413) 650-6329."
Insulation Wall Roller https://www.sprayinsulationindustries.com/product/insulation-wall-roller/
Just out of curiosity, what part of Atlantic Canada are you in? If you don't mind.
