Do you mean for decking floor boards? I usually specify eastern white cedar, though it's on the soft side and is getting expensive. Last year I used eastern Larch (aka Tamarack, aka Hackmatack) for a small deck at my house. Friends who have access to black locust say it makes a great deck, but it can be hard to find.
The ones with a resin/wood-flour core tend to fail, from what I've seen. Manufacturers of any type that claim to use recycled material often use post-industrial (i.e., pre-consumer) waste, which is probably a good thing but not as helpful as using post-consumer waste. Plastic decking gets very hot in the sun, it sags between joists, it either gets moldy or it's treated with mildewcides that have negative environmental impacts, etc..
How about recycled composites? Some are up to 95% recycled, I believe, they last a long time, and will even take offcuts back as scraps to recycle.
