Damper control motor
![](https://secure.gravatar.com/avatar/857bf07b9a8eac78366ce6c426e7118c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I have a 36″ whole house exhaust fan mounted in an attic dormer with a gravity damper. I want to add a damper control motor. Problem- the fan is a two speed, wired from down stairs and the damper motor needs only one input. I think I need a relay to make it work. What kind of relay is required? Thanks.
Jim,
I'm not an electrician. There are lots of ways to do this, I imagine. But a current-sensing relay would work:
http://www.grainger.com/category/current-sensor-relays/relays/electrical/ecatalog/N-8ek
