Cut and Cobble inboard of structural brick
![](https://secure.gravatar.com/avatar/a0e43c762fa7c8a1e73e5e60cecb3419?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I’m renovating our kitchen in Philadelphia and have framing inside the two exterior walls (double-wythe brick). I was planning to spray foam (and hold my breath regarding freeze/thaw) but due to lead times and high cost/sf due to the small area being addressed, I’m leaning towards cut and cobbling. I realize the energy benefit to insulating one room of our house will be limited.
One wall is conventionally framed 2x4s and the other is a 2×3 plate with 2×4 studs on the flat. I have some 3″ polyiso to use for the conventionally framed wall and was thinking I’d get 1″ sheets of foil faced polyisio to use on the 2×3 wall sliding 1 sheet behind the studs and sealing those seems with foam before adding a second layer in the stud bays.
My questions:
1. Do I need to seal with caulking or can I rely just on the spray foam?
2,Considering the diminishing returns with a partially insulated house, is it worth my time to cut and cobble as opposed to a careful air sealing of gaps and cracks and installation of an alternative and easier to install material?
3. Is all this ill-advised or is there a better approach?
Thanks!
Anthony,
Have you considered using a DIY closed cell spray foam kit? Something like this: https://tigerfoam.com/sprayfoaminsulation/.
I did briefly but the increased cost and potentially less than advertised yield scared me off. I may change course depending on how things go today. Thanks
