Crawlspace and radon
![](https://secure.gravatar.com/avatar/84e9ae7f413e4c3ebd28e09dcf332bd2?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I have a room in the cellar that I dug down from a crawlspace to make a 7 foot high room. So, I have a dirt floor with three feet of dirt up to the cement footings. I have laid 6 mil plastic and sealed it to the footings to prepare for cementing. But now it looks I need to prepare for radon mitigation. I heard the I can dig a 10 foot trench, add crushed stone and put in a perforated pipe with a “T” to protrude above the cement. Will that work, or do I need to add crushed stone across the entire floor before I cement?
Hi SH2020.
When it comes to installing a radon mitigation system, I recommend you read this: All About Radon
I am curious...you dug out the earth next to the footings, straight down? Did you consult an engineer?
Hi Brian,
No, only dug to within 3 feet of the wall.
So there should be a perforated pipe buried in the crushed stone. All around the perimeter? This area is 20x 15, I know they just drill a hole to the crushed stone in existing cellars and it works.
