Crawl space ventilation
![](https://secure.gravatar.com/avatar/cc82e66988a7a7c55c66de5c5fb63645?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
Hello,
I am building a raised floor wood construction home in the Monterey Peninsula, CA. The current plan to keep the crawl space dry and ventilated is to put a rat guard, seal off the space, and add a 75+ cfm fan that will have tubing that will draw & supply air from exterior locations. The footprint of the crawl space is about 3700 SF. The height varies from 1.5′ – 2′.
My questions are:
Is this a good plan?
What would be good exhaust and supply locations?
Can you recommend a reasonably priced fan for this application?
Much thanks,
Barbara
Barbara,
What's a "rat guard"? Is that a California expression for what the rest of us call a rat slab?
Is this a house with a post foundation, or a house with a conventional crawl space foundation (perimeter concrete walls)?
If you are planning a conventional crawl space foundation with perimeter concrete walls, I think that an unvented crawl space makes more sense than a vented crawl space. For more information on crawl space details, see Building an Unvented Crawl Space.
Why "locations" vs a single point fan, no ducts and numerous vents?
Rat Slab's Canadian equivalent is called a Scratch Coat. Our rats are much too polite to burrow into a crawlspace.
Malcolm,
In my vocabulary, a scratch coat is for walls, not dirt floors.
A stucco job consists of three coats: scratch coat, brown coat, finish coat.
Thanks for the responses. It is a rodent guard slab. Yes, it is conventional crawl space foundation with perimeter concrete walls. In our county,if it is sealed then it must be mechanically ventilated at a minimum rate of continuously operated mechanical exhaust ventilation at a rate equal to 1 cubic foot per minute for each 50 square feet of crawlspace floor area, including an air pathway to the common area (such as a duct or transfer grille).
Barbara,
The details you need to follow are explained in my article, Building an Unvented Crawl Space.
Thanks Martin
