Basement & crawl space radon mitigation
![](https://secure.gravatar.com/avatar/62f0815be00fc67e83c225d58bdf8aba?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Lexington KY home with ~20 PCi/L radon levels in a basement adjacent to a crawlspace (see attached plan). Radon levels directly above the crawlspace are ~14 PCi/L. The sub membrane radon mitigation design shows a 50ft perforated drainage pipe as a continuous loop. Is there be any reason NOT to loop the 50ft drain pipe? Has anyone done something similar?
Thanks – Bob
House Notes:
– House was built in 1972
– CMU block basement and Crawlspace
– Tight clay soil under basement slab
– Crawlspace is uncovered/bare and composed of rock and dirt.
– Rafters/rim joist in crawlspace are uninsulated and not covered with a membrane.
– Basement walls/ rafters are uninsulated and not covered with a membrane.
– Crawlspace is not vented
– The rafters supporting floors above basement and crawlspace run across the block walls without any rim joist or seal (vented to the basement…).
– There is duct work that runs across block wall (6″ metal) I have yet to see it condensate, a ~32″ return (2 joist bays) turns up the stud wall directly above the block wall. Gas lines and electrical lines also run over the block wall though the open joist bays.
The main question is whether or not a continuous loop of 4" perforated drainage pipe, sealed under an encapsulated membrane, will create additional airflow resistance in the system? My gut tells me that the continuous loop is probably a hindrance, but I have nothing to lean that on.
- Bob
