Corner cap options?
Jc161928 | Posted in General Questions on
Anyone know of a way to integrate these corners in a water tight way with wood, probably cedar?  Perhaps utilizing butyl tape or foam tape?  I am not sure I can get a metal profile that will go around these corners.  Furthermore the next corner may have some copper features that I would like to seperate from metal.  Thank you.
  1. Malcolm_Taylor | | #1
    Justin,
    Sorry - I missed your reply in the other thread.
    The two common options for a wood corner are:
    - Run it over the shingles. That's what most builders do with lapped cladding like Hardi-planks. The method is somewhat susceptible to wind-blown rain, and water intrusion while moving the trailer.
    - Butt the shingles to 5/4 corner trim. If you run flashing tape or a membrane strip so that it laps the joint, and back-bed the shingles in caulking as you install them, that would be my preferred choice.
  2. Jc161928 | | #2
    Hey thanks again Malcom!
    For the corner trim are you talking 5" by 4" corner flashing of some kind? I am not sure what you mean by back bedding the shingles in caulking? Do you have a photo reference maybe?
    Thank you!
    1. Malcolm_Taylor | | #3
      Justin,
      No 5/4 wood trim you butt the shingles up to. Before installing the shingles against the trim, run a bead of caulking in the back corner to they bed into it as they go up.
