Confusion on Exterior door – One or two slopes?
![](https://secure.gravatar.com/avatar/96f25f52a9932644dfaedf0a0d0c15d3?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
New builder Evan here, getting ready to put an exterior door on my 8×10 tiny cabin in Vermont. With your help I got the floor, walls, and roof built and I will install the final window tomorrow!
I have read as much as I can find about the proper way to flash my exterior door, which will be highly exposed to rain/snow. This 2018 article by Martin (https://www.greenbuildingadvisor.com/article/flash-exterior-door) led me to the following plan:
Create and install a sloped sub-sill from 1x pressure treated lumber on top of my subfloor. Will be installed with exterior screws over 3 beads of sealant. Then I will use 3M All Weather flashing tape to flash that sub-sill similar to my windows. After the sill and rough jambs are flashed I will install my door frame (jambs and header), with the bottom of the jambs cut on a slight angle to match the sub-sill angle. Then I will install a sloped metal threshold in between the jambs, something like this: https://www.homedepot.com/p/M-D-Building-Products-3-ft-x-5-5-8-in-x-1-1-8-in-Oak-Aluminum-Threshold-78600/100124956. Then I will install the door.
The reason Im confused is because, in this set up, which appears to be recommended in Martin’s article, I am installing two sloped items – a sloped sub-sill/sill pan and the sloped threshold. Is that correct? Do there need to be shims to create a level surface for the threshold to sit on? Elsewhere, like in this Q&A (https://www.greenbuildingadvisor.com/question/outie-doors) post, Martin shared a photo where the sub-sill does not appear to be sloped and only the threshold is sloped. Most sources I see online include either a sloped sub-sill or sloped threshold, but I havent seen both. Any advice you can offer would be really helpful, I hope to install the door in the next 48 hours (after the final window).
Thank you!
Evan
Evan,
Here is how Hammer and Hand do it: https://hammerandhand.com/best-practices/manual/3-windows-doors/3-4-door-installation/
Thank you Malcolm! Very interesting, it looks like they create a flashed back dam with L metal and install the threshold directly on that - basically right on the subfloor. So only one sloped at the sill/threshold level, and no subsill. Sounds different from what I'm reading here on GBA. I'll look into the L metal idea and see what I learn. Just installed the last window today!
