ConditionedAttic-PortlandOregon(zone4)
![](https://secure.gravatar.com/avatar/215aad7d8f3f610254392307f18bf368?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Trying to take this 1970’s attic and make it a conditioned space (not a living space) so that I can maintain the HVAC that are the heating and cooling of this 1600ftsq ranch.
My 1st stab was to take this wall and roof profile from Rockwool (see below). Not a contractor but the owner, but felt I could handle Rockwool 2’x4′ 2.5″ panels and do a reasonable job.
Ran this past an engineer and the weight exceeds the truss tolerances so that only 1 layer of 2.5″ Rockwool is within limits. Not sufficient insulation. Trusses are 2×4 on 24″.
What recommendations for a roof assembly to support a conditioned space attic and any contractors/roofers in the Portland area is anyone familiar with that could do an install of ideas/recommendations.
thanks
Tommy,
Have you considered a similar assembly but substituting foam for the rockwool? Weight then wouldn't be an issue, and it could be left un-vented.
Malcolm thanks for responding!
Every time I look at foam for the roof exterior, I'm concerned with the ozone impact of slow blower agent release and global warming potential. Trying to be a good steward.
What foam assembly has minimal HFC and global warming over the life of the roof assembly and if you could point me to a URL describing the technique that an expert member of greenbuilingadvisor.com would recommend. I'd like to get well above R40, eliminate thermal bridging, etc.
Thanks!
Tommy,
Our company did a spray foam-free retrofit on a single story ranch in Portland, OR where we created a 'headhouse' to store the mechanical equipment. One could swap out the foam baffles with a wood fiber insulation product if one was looking to go completely foam free. I've attached the details here along with a pic of the finished space. We were able to fur down the 2x4's with a site made plywood truss and then create a vented and insulated assembly. We then added Siga Majrex as a smart vapor control and air barrier to the underside of this. The assembly was then filled with cellulose insulation. More info is available on IG, link here: https://www.instagram.com/p/CUlEmbhhD_I/
That, I think, is a bit beyond my skillset.
You have a video, "Building a Vaulted High-Performance and Foam-Free Roof Assembly" which I thought was wonderful. Wish I had that option.
Tommy,
You may find this useful: https://www.greenbuildingadvisor.com/article/choosing-rigid-foam
EPS/GPS seems the choice at this point.
With a vapor permeable membrane over the current sheathing, can I confidently assume the sheathing will dry to the outside regardless of the EPS/GPS thickness?
Portland-Zone4, is there any negatives to using furring strip to mount metal roofing with the created air-gap.
thanks
