Condensation on an aluminum door
![](https://secure.gravatar.com/avatar/f7fc44d05d05ec385281969d1f625cb0?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Came across something interesting. A new insulated door had been installed. Its a mobile home door, so its frame is aluminum. The condensation was dripping from the inside of the frame. Is there a detail for this type of door, to prevent thermal bridging, or condensation?
Shane,
I would say that mobile home components are not known for their energy detailing.
It's always safer to use components designed for a real house. However, if the door was installed in a mobile home, there's not much you can do about it, unless you want to remove the door and the jamb and try to install a real exterior door with a wood jamb.
Congratulations. You've just seen proof that aluminum is the most excellent conductor of heat among all common construction materials. Thermal bridge par excellence.
