Concrete sealer needed before finishing basement?
I live in a home in Zone 5a that was built in 1978 with a poured concrete basement, our house sits relatively high with ground sloping away from the foundation. We are planning on finishing out basement it with XPS and then metal framing/drywall.
My question is do I need to seal the concrete before I put up the XPS? I did the plastic wrap test and it resulted in no condensation but we have a dehumidifier down there and it runs quite a bit. I do not want to pay $200ish to seal the concrete if its not needed, but I also do not want to put up the XPS and drywall to and make more problems later.
Side note: I was planning on using Okon S-20 concrete sealer is that overkill? Is there a cheaper or better way?
Patrick,
If you have lived in your house for many years, and never seen signs of liquid water entry through your basement walls, there isn't any reason to install a sealer on your walls.
If your time frame is more limited -- if you've only lived in the house for one to three years -- you may decide that the cost of the sealer is cheap insurance. It's your call.
Here is a link to an article with more information on the topic: Fixing a Wet Basement.
