Wingnut Moisture Test
![](https://secure.gravatar.com/avatar/62f4d57e60ce585fda426b2cc3ebfe8d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Will taping a piece of clear poly to a concrete slab offer a good idea of moisture content?
Is there a minimum size required for an acceptable test result?
Will room temp and concrete temp affect results?
Thank you, Daniel
Funny, I was researching this very thing today. There are very affordable and simple Vapor Emission Test Kits available that follow the ASTM F1869 standard. A pack of 3 from Humboldt Construction Materials Testing Equipment is $36. Seems easy to use.
Daniel,
Yes, although it's worth remembering it only give you a snapshot in time. A slab without a functioning vapour barrier may be dry for part of the year and not others. The poly test is better at telling if you have a problem, than telling if you don't.
I believe that the foundation is well protected from the intrusion of moisture and hoping that testing it might offer a general idea of the year-round moisture content: I poured the concrete over a 20" base of crushed stone on a site that slopes away on all sides and is well-draining. I used vaporblock 15 along with the xps insulation beneath the concrete, and I have deep overhangs and perimeter drainage.
