Concrete fasteners loose?
PLIERS | Posted in General Questions on
So I started securing 1×4 strips to concrete basement wall. I have 4in fasteners going through 2in rigid foam and the 1×4. There is no size between 4 and 5in screws and according to instructions I shouldn’t go deeper than 1 3/4 into concrete. Some screws went in snug a few were loose enough I could pull it out if I pulled hard enough. I took foam board adhesive and glued the whole piece of wood and then secured what I could. I can pull hard on wood and it doesn’t detach but I bet I could get it out with a claw hammer and some effort. Do I need to worry, it’s only hanging drywall. I could go back with some 5 inch tap cons if necessary I mean it’s only a “1/4 too deep”
  1. Malcolm_Taylor | | #1
    Hammer,
    Ditch the Tapcons. They are finicky and fragile. Buy a few of these instead.
    https://www.grkfasteners.com/specialty-accessories/caliburn-concrete-screw
    1. Malcolm_Taylor | | #3
      Patrick,
      There is something strangely endearing about Hammer repeatedly asking a barrage of questions about small routine tasks and then ignoring the advice he gets.
  2. PLIERS | | #4
    Thanks I reread the advice, grk fasteners at least a concrete version is very hard to get around me. My options would be to wait a few days to a week for the fasteners to come in or I can try:
    A. Using a multi purpose grk fastener with copper wire as Patrick mentioned
    B. Or I was thinking Is it possible to use copper wire with the concrete screws I have now (they aren’t tapcons, something called confast). You can buy bare copper ground wire at the big orange guy for about $25. It would just save me the hassle of buying more screws
    BILL WICHERS | | #5
    Tapcons work OK but you absolutely must drill the hole properly. "Properly" means you use a correct size drill bit, and it ESPECIALLY means you DO NOT rock the drill while drilling -- if you enlarge the hole even a little, you'll have problems getting the tapcon to hold.
    My recommendation would be to use an SDS-plus ("plus" is the smaller shank version of the SDS system) rotary hammer, and a Bosch masonry bit. This will do a good job. My second recomendation if you're having trouble is to use 5/16" or larger tapcons. 1/4" tapcons are the most fussy, the larger ones hold better with less issues. I've found the 3/8" tapcons to be near invincible (I mounted a shelf for a water tank with some of those), for example. 1/4" tapcons are very, very fussy about their holes, and there is very little room for error. Any larger size tapcons seem more tolerant of less than perfect holes.
  4. PLIERS | | #6
    This morning after searching everywhere for the grk concrete screws, I saw I had Simpson star drive concrete screws. Gave it a shot and went it smoothly. I have come to a conclusion, I hate tapcons and Amazon knock offs. I’m sure the grk fasteners would have worked as well if I had time to order them.
      BILL WICHERS | | #7
      You'll probably hate Amazon knockoffs of any type of fastener. There are a lot of of questionable products on there, and for anything critical (structural screws, etc.), I would buy only from reputable construction suppliers.
