Cold weather XPS adhesive?
![](https://secure.gravatar.com/avatar/b6a35ff077ddb6fe38e1c7840a237081?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Hi all! I am trying to use the Christmas break to glue XPS insulation to my interior basement walls. Unfortunately we are having a cold snap so I need to find a cold-weather adhesive that can work in lower temperatures. Most all I’ve found say 40F and up, I need more like 30F and up. Does this even exist? Any other suggestions on how to get this done? Thanks in advance!
-Mike
How about fasteners instead of adhesive... like Marc Rosenbaum did here: http://blog.energysmiths.com/2011/08/basement-insulation-part-3.html
If it's not too late, change the rigid foam to polyisocyanurate (fiber or foil faced), which has a much lower environmental impact, and a comparable or higher R/inch. XPS will eventually fall to R4.2/inch (same as EPS) as it loses it's HFC blowing agents (powerful greenhouse gases with greater than 1000x CO2 potential at 100 years. Polyiso is blown with pentane (~7x CO2). Polyiso also won't melt into a flaming puddle in the event of a fire the way XPS does.
If your basement walls are measuring under 40F, raising the temperature of the basement with space heaters can usually take care of that.
(Erik- is J. racing in the WaWa night league again this year? Sure beats bowling! :-) )
Mike,
I'll echo the previous suggestions: either use heaters to raise the temperature of the space, or switch to mechanical fasteners.
I recently used Sikaflex and PL Plus polyurethane construction adhesive in the 30's with no apparent problems. Neither melts XPS
Oh, and I used a 'T nailer' to hold the foam up while the adhesive set. Not fit for a finished look like the fasteners Marc used, but I was covering it anyway
