Code on placement of anchor bolts in bottom plate of 2×6 width-wise
![](https://secure.gravatar.com/avatar/675d73deb42355324e6bc666f6116ded?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
Anyone know the code for bottom plate anchor bolt placement from the short edges 5.5 inch (2×6)?
I am not talking about the min. OC or from ends of boards, but rather from the edges.
My bottom plate is cantilevered 1.5 inches over the stem wall. So, about 4 inches are sitting on the stem wall and the other 1.5 inches is resting on the slab. I want to verify the portions of the middle of the board that we can use to help ensure the ABs don’t blow out the stem wall when driven/drilled/inserted.
Image atch’d….very sketchy image.
Thx.
Middle third: https://codes.iccsafe.org/content/IRC2018/chapter-4-foundations#IRC2018_Pt03_Ch04_SecR403.1.6
Thanks michael.
