Coating for a galvanized roof
blueshead | Posted in General Questions on
I live in South Louisiana and I have a galvanized rusty roof that I have to live with.
What is a good coating that I can use.. Thank you.
  1. GBA Editor
    Martin Holladay | | #1
    Mark,
    Any good paint store should be able to help you select the right paint for your galvanized roofing.
    Most sources recommend that you begin by power-washing the roof.
    Then you will need a primer designed for galvanized steel -- sometimes referred to as an etching primer -- followed by a paint designed for metal roofing.
  2. blueshead | | #2
    I'm looking for a rubberized, waterproof coating.. With heat reflective ability.
    Dana Dorsett | | #3
    The CRRC search function has a number of coating products listed, along with solar reflective index ratings. See:
    http://coolroofs.org/
    http://coolroofs.org/products/results
    You'd have to consult the manufacturer for how to make it stick reliably over time on galvanized roofing, but I'm sure there are several that would work.
  4. dankolbert | | #4
    Gaco makes a very nice product - http://www.gacoretail.com/gacoroof.html
