CLT Insulation Questions
quackhunt | Posted in General Questions on
I’m in the process of designing a new home that will be built on Table Rock Lake near Branson, MO.  I have a desire to utilize Cross Laminated Timber as the roof structure and was hoping to get some thoughts/feedback on my plans for insulation for the home.  Attached is a rough design of the wall/roof assembly showing my thoughts on how I plan to insulate the walls and roof of the home.  I’ve tried to educate myself on the ideas/concepts of a “pretty good house” but not sure I’m fully understanding the insulation design for my region(4A).  Currently my plan is to frame exterior walls w/ 2×6 at 24″ oc cavity filled with cellulose w/ a continuous layer of insulation on the exterior of 1.5″ Zip system R sheathing.  I believe this will get me roughly R26 in the walls.  The roof would be a 4.125″ CLT panel w/ 5.5″ of poly-iso on the exterior of the CLT panel.  I believe this will get me roughly R40 for the roof.  Side note, the roof will be UNVENTED since I plan to expose the CLT panel to the inside.  Attached is the detail of the wall/roof assembly.  Thanks in advance for any help.
  1. walta100 | | #1
    You have a plan in your head but consider making the walls taller with a flat ceiling covered in cheap fluffy insulation for much less money you get more interior space R60 insulation and the ever reliable vented attic.
    I have never been sold on Zip+R. My gut says it makes a weaker wall. See if you can find someone to install your siding over sleeper and sheet foam.
    Akos | | #2
    I would read through this CLT build here:
    https://wolfeislandpassivehouse.wordpress.com/category/roof/
    From what I understand CLT needs an air barrier on the outside. You would want something to protect the CLT till the roof is installed thus I would put a layer of peel and stick over it and then install the rigid.
  3. Malcolm_Taylor | | #3
    quackhunt,
    Extending the CLT to form the r0of overhangs is the simplest, but leaves you with thermal bridges at all the exterior walls. From what I understated most CLT roofs use outriggers at or above the foam layer instead.
