Closed cell or open cell spray foam
![](https://secure.gravatar.com/avatar/d03b7f974a1d97be036d5cd41b720eb8?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
you have helped me before. i have decided to do a spray foam insulation. the building is pole barn type build [wood] covered in sheet metal. it has a concrete floor,insul garage door an it will have a/c only, it also is located in central fla. i,ve had 3 different contractors with 3 diff ways of doing it. one is closed cell on walls an roof an he said 1/12 “” is all thats needed. he had the best price [ still not cheap]. the next guy wanted to close cell the roof an open cell the walls. the nexy guy wanted to open cell the whole building the most $$$ so now what is the best way to go?????????? I lean w/#1 because i think closed will perform better….. what do you think
You haven't said what the thickness/R-value of each choice is.
