Closed-cell spray foam and fiberglass combination system in exterior wall
![](https://secure.gravatar.com/avatar/ad733954f28a2268aa696c4f9146b249?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I am building a new home in zone 6 and am considering using 1″ of spray foam insulation on the inside of the wall sheathing, and then filling the remaining area with 6″ fiberglass. Wall framing is 2″x6″.
I am looking for some feedback on using this method. I would appreciate your thoughts.
Thank you.
Rocco,
In Climate Zone 6, I wouldn't use less than 1.5 inch of closed-cell foam for this type of flash-and-batt installation, and 2 inches would be better.
Here is an article on the topic:
https://www.greenbuildingadvisor.com/fine-homebuilding/why-flash-and-batt-makes-sense
Thank You!
