climate zone 5 – unventilated exterior roof insulation
![](https://secure.gravatar.com/avatar/5ba073d87fe983d28202f242306ac2cd?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Does someone mind sanity checking my plan?
Following https://www.greenbuildingadvisor.com/article/how-to-install-rigid-foam-on-top-of-roof-sheathing
The layers go as follows
– metal roof (standing seam)
– peal and stick ice and water shield (from drip to ridge)
– 1/2 inch decking
– 2 3 inch xps layers offset under decking (top layer taped)
— r30
– 5/8 roof decking
– in cavity insulation to bring up to a theoretical r73 total (41% of insulation is the exterior foam in climate zone 5)
— will certainly be less, maybe target r30 rockwool for r60 total. (maybe Roxul ComfortBoard)
— this brings us to ~50% exterior insulation, which is safer and targets climate zone 6
How r u getting r23 from 3 in xps? R val is 5 per inch
2 three inch layers of xps, offset from eachother (total of 6 inches of xps for an r value of 30)
that could probably be formatted better...
Oh—now i c ! My bad! I thought u meant “two to three” as in “two or three”. Sorry about my confusion!
Use EPS instead of XPS. If you use low GWP XPS anyway, derate the R value to the minimum value after many years (ie < R5, maybe R4.5).
Air sealing and testing to verify is always important.
Consider a smart-retarder on the interior side. Otherwise a Class III.
Sounds good, will probably be level 2 drywall finished (unpainted) if anything.
