Cinder block retrofit
![](https://secure.gravatar.com/avatar/30f30cd53e2ddfcd122aee1fdd7e20c4?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I have a cinder block home in Zone 5b (WA state) that needs new windows now but I plan to add exterior insulation and siding in the next 2-3 years. I will most likely insulate with the Legalett Thermalwall PH system. What would be the best way to install the windows now and ensure that I can still add the insulation later? My concern is not being able to insulate the block window frame if I just install the windows directly into the block.
