Gap between concrete footing and block
![](https://secure.gravatar.com/avatar/042842544857e53935792f1a2e3f7926?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Hey everyone. I have step a step footer and obviously my home is built into a hillside.
My question is can I or should I patch this gap (see attached picture) between the upper footer and the lower row of block?? This picture was taken from inside the crawlspace and I plan to seal the outside of the block. How would I seal the block with this gap between the block and the upper footer? I dont want water getting in here but not sure if I patch the gap with mortar and then seal over that??
Thanks for any help
Hi Chris -
Always way better to waterproof from the exterior than the interior. And always better to waterproof than damproof; waterproof has crack-spanning capacity and resists water under hydrostatic pressure to a minimum of 8 feet.
Take a look at this video: https://www.youtube.com/watch?v=WKRIPHq7WtY
And the best way to avoid hydrostatic pressure is with a perimeter drainage system at your footer.
With these two defenses, I would not worry about the interior gap in your photo.
Peter
