Chimney and ceiling insulation
![](https://secure.gravatar.com/avatar/6fe7085ce52ab95ae9c678e691a4e0cb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I’ve been struggling with how to “legally” and safely get a class a chimney through r80 insulation in a ceiling The listed hardware only accommodates 10″ of insulation above framing. Is the only alternative build a plywood box (chase) that provides 2″ clearance around the chimney from ceiling to roof? Would an 8 sided duct made of duct board be a safe and legal “chase”? Can the “chase” end short of the roof?
It may depend on the pipe manufacturer you choose. I just installed ICC Excel class A woodstove pipe through 20" of cellulose. There is a ceiling support piece that handles the first 10" or so, then an extension above that for the rest. On top of the extension is a storm collar (inside the attic) that keeps insulation from falling down into the air space. http://www.icc-rsf.com/en/icc/view-all-products
