Changing Function Codes on Minisplits
When changing function codes on a Fujitsu minisplit, can I do more than one at a time? The manual is unclear. Or do I have to change the code and reset breaker for 2 minutes every time?
Having to reset the remote every time really confuses things.
Thanks
Kevin
You may want to call Fujitsu technical support or post this question on a Fujitsu discussion thread.
Any updates of this ? Are both the Mode and Start/Stop buttons entered after each setting ? or just the mode after each followed by a single start/stop when finished ?
