CC Spray Foam is a vapor barrier, so for basement brick is it (a) ideal, or (b) a nightmare? Does brick need an air gap before foam?
![](https://secure.gravatar.com/avatar/59bb9de3b4909e93c5bf7b4bd7518464?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Other people say spray foam is a nightmare for basement brick because it is a vapor barrier.*
Rigid foam with spots of adhesive attaching it to the brick – and with spray foam at the perimeters – would have the same vapor-trapping effect.
Despite popular opinion, closed cell foam isn't a complete vapor barrier, it's a vapor retarder, at somewhere around 1 perm at 2" and dropping the thicker it gets. But using it can definitely result in brick absorbing water, which then spalls in freezing temperatures. Martin wrote about the subject here: https://www.greenbuildingadvisor.com/article/insulating-old-brick-buildings.
