Caulking with closed cell insulation
user-4145989 | Posted in Green Building Techniques on
I am building a new home with R30 and R 50 walls and ceilings. We will have 3″ of closed cell in the basement walls.
What are best management practices for caulking?
Thanks in advance.
Peter Whitman
  1. GBA Editor
    Martin Holladay | | #1
    Peter,
    I'm sorry, but I don't understand your question. I'm guessing that you want to ask something like "Is it possible to build a house without caulk?"
    Or maybe "Where should I use caulk?"
    Or maybe "How many tubes of caulk should I buy?"
    Or maybe "Will my tubes of caulk be damaged if I store them in a location subject to freezing?"
    Or maybe "How do I clean my fingers after I use my fingers to smooth a caulked seam?"
    But if you aren't more specific, it's hard to guess what you want to know.
  2. user-4145989 | | #2
    Sorry for the lack of specificity.
    Is it necessary to caulk the inside and outside of the foundation plate if I am spraying closed cell insulation on the interior framing covering the plate.
    Also, how do I clean my fingers after I use them to smooth a caulked seam?
    Thank you in advance.
  3. GBA Editor
    Martin Holladay | | #3
    Peter,
    Q. "Is it necessary to caulk the inside and outside of the foundation plate if I am spraying closed cell insulation on the interior framing covering the plate?"
    A. By "foundation plate," I'm assuming you mean the pressure-treated mudsill. (At least that's what we call it here in New England.)
    If you are building a home with a basement or a crawl space, it's possible to cover the crack between the mudsill and the foundation wall with interior spray foam. However, that's not enough for a good air seal. At a minimum, you want to install foam sill-seal between the foundation and the mudsill at the time when the mudsill is installed. After the house has been framed, providing some weight on the mudsill, it's usually a good idea to caulk this crack on the interior for an improved air seal. Alternatively -- a more expensive but better option -- the crack can be sealed with a high-quality European tape like Siga Wigluv.
    Then, after the caulk or tape is installed, a little spray foam in addition never hurts.
    If you are building a home on a slab foundation, I doubt if you will want to cover the crack between the mudsill and the slab with interior spray foam. In this case, just like the house with a basement, I recommend foam sill seal and (later) caulk.
    Q. "How do I clean my fingers after I use them to smooth a caulked seam?"
    A. Use an old T-shirt dampened with a little water or a damp paper towel.
  4. user-4145989 | | #4
    Can I use the Siga Wigluv to seal the exterior between the mudsill and top of foundation?
    Thank you for your continued advice.
  5. GBA Editor
    Martin Holladay | | #5
    Peter,
    Q. "Can I use the Siga Wigluv to seal the exterior between the mudsill and top of foundation?"
    A. Yes.
