Caulk for sealing bottom plate to OSB?
icandoamazong | Posted in General Questions on
What caulk is recommended for sealing the bottom plate to OSB? Any acrylic latex work?
    Akos | | #1
    For air sealing, I tend to use green glue SEALANT (not the compound, black and orange tube).
    I've removed sections that are a decade old and the sealant is as flexible as the day installed. It is also water based unlike most flex sealants.
  2. Jon_R | | #2
    I suggest a test. Apply a typical line of sealant, wait 24 hours, squeeze together very hard with clamps, then release. Test for air tightness. I expect that in some cases, sealants that never harden will be pushed out, providing less air sealing than a good +100%/-50% PU sealant (eg Dymonic 100).
