Caulk for framing members, windows
![](https://secure.gravatar.com/avatar/41e8a5e4a6b019262d6c83731b8d376e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
What caulk do y’all recommend to seal the gaps between double studs (before attaching drywall), bottom plate to concrete foundation and around windows (in combination with backer rod)?
I’m a big fan of Osi Quad for exterior caulking jobs, so I figured I’d use that. I had to stop after a few minutes since the fumes are intense when used inside. I have three little kids running around I don’t want to expose to that smell.
Are there any alternatives that have the same longevity as Polyurethane caulk, that are safe to use inside?
I use polyurethane sealants for all that stuff. I've never had a problem using them inside, either, at least any from Loctite's PL line which is what I usually use.
Construction adhesive can work between doubled studs too, but since I like to use PL premium for that kind of thing these days, it's polyurethane just like the sealants...
I have seen some very old silicone caulk that has held up fine, but it wasn't exposed to sunlight or the weather. If you're indoors, a good quality silicone will last a long time too, but will tend to be stinkier than the PL sealants.
Quantumgirl, I like this sealant: https://foursevenfive.com/contega-hf/. It's ultra-low VOC so no fumes to worry about, it sticks well and stays slightly flexible forever.
